Over heated engine
Old Apr 11, 2018 | 11:44 PM
Jake2k2's Avatar
Default Over heated engine
A couple days ago my 242 turbo over heated and I have checked all symptoms for a head gasket being blown and the oil looks fine but when you start it it barely runs and stalls after 6 ish seconds with gas pedal on. and makes weird high pitches ”tss” noises under the hood every two or three seconds. There had been no leaks and the exhaust is not Smokey. And the oil pressure gauge bounces up and down. Anyone have any ideas to help me?
Old Apr 12, 2018 | 01:36 AM
dytha99's Avatar
Compression test
Leak down test
Old Apr 16, 2018 | 03:34 AM
usual cause of overheating is lack of coolant. or lack of coolant circulation. IMHO, most common cause is a blown heater hose, or a broken water pump belt.
head gasket failures cause loss of compression, and/or intermingling of coolant and oil.
Old Apr 16, 2018 | 08:42 AM
Jake2k2's Avatar
Thanks pierce I figured out a vacuum hose connected to a check valve cam off and I lost all compression and I had low coolant but there is no damage to me engine
trstrugar
May 28, 2015 08:20 PM
PinnacleWax
Mar 12, 2014 04:18 PM
Brian Wilson
Apr 1, 2013 08:57 AM
bigrb247
Dec 19, 2009 05:00 PM
