parking lights inop,92' 240 and the fix
Old Apr 25, 2012 | 01:07 PM
troys1992v240's Avatar
Default parking lights inop,92' 240 and the fix
My right rear parking lights went out after I had already replaced the bendable circuit. Board and gasket. Turns out I took off the connector and it was all wet. The housing was holding water as well. I Installed new whole rt.rear Assy.(FCP GROTEN) with gasket and a thin coat of silicon sealant on BOTH sides of the gasket and a generous portion across the top. They still didn't work and the brown and white wire that feed had no voltage. I then replaced the light integrity. Sensor (ipd Volvo) and still nothing. What found was the fuse for the RT. Parking. Light was corroded slightly on the front contact. I removed all fuses and brushed all the brass holder prongs with a small wire brush from lowes. I then applied a thin coat of dielectric grease on the brass prongs. I also slightly bent a few prong to give more holding strength and reinstalled fuses per the fuse cover. This has solved my problems w the lights.
drenman
Nov 29, 2016 07:35 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
troys1992v240
Apr 1, 2013 09:14 PM
voget
Aug 9, 2007 07:25 PM
