Poly Bushings
poly is good for the front. they are pretty easy to install. you have to melt out the front rear bushing from the bracket then use the shell. the front bushing needs to be pressed out and then you push in the new poly.
just make sure you use a good poly grease when you install them. you can even go as far as we did and install grease fittings/grease groves, so you can squirt new grease in when it needs it.
here is a feedback thread: http://forums.turbobricks.com/showthread.php?t=195431
Platinum52
07-17-2009 07:33 PM
