Potential Volvo 240 flywheel/starter problem
I have a technical question on my 245 Wagon. After I start driving it a little; it drives fine. But then I here a very loud mechanical type of grinding. It sounds like the flywheel is engaging the starter while I'm driving it.?
It this a common 240 problem and do you have any opinions on this? Any info would be greatly appreciated.
Thank you very much for your time.
RE: Potential Volvo 240 flywheel/starter problem
Power to the starter solenoid should only be when the ignition switch is in the START position. I've had ignition switches go bad after 15-20 years, although not on my Volvo. Not too many possible problem areas. Check out the ignition switch.
bentshackle
04-28-2009 07:01 PM
