Power Window Driver Side 1991 240
Old May 13, 2012 | 03:48 PM
abuendia's Avatar
Default Power Window Driver Side 1991 240
I need to know how to remove this window and install filler strip.
Old May 14, 2012 | 10:45 AM
swiftjustice44's Avatar
Are you referring to the weather strip on the outside edge or the strip on the inside edge that is "furry" and holds the window in place?
Old May 15, 2012 | 02:44 PM
abuendia's Avatar
I am talking about the strip that is about 15" in length that is place at the bottom edge of the window that is seated in a metal channel that hold the window in place.
Old May 15, 2012 | 03:15 PM
The only thing that holds the metal track to the bottom of the actual glass is a nasty black adhesive. My experience is once the o.e. stuff loses its grip, no after market adhesive comes close to retaining the same hold. Generally, I grab another window from a salvage car rather than jack with the attempt. Should that not be an option, then there is a roll of "tape" of asphalt like consistency used to seal a/c fittings. It has a paper separator between each layer that one removes prior to installation. Works as good as anything I have found.
BuzzBrick
Jun 29, 2011 07:38 PM
rjb44
Aug 27, 2010 05:12 AM
cshields
May 23, 2010 01:13 PM
J Dubb
Oct 14, 2009 11:58 PM
flac124
Dec 30, 2008 05:47 PM
