Pressure inside engine block
Hello everybody,
I am working on my "240" and I replaced nearly everything attached to the engine from sensors, to bushings, firetrap, hoses etc basically it should be all new and the engine should be breathing well but when I finished yesterday with this task and started the engine up for the first time since I started replacing all of it. The engine started right up but the entire engine is shaking and it is running a bit high to....but what concerns me most is that pressure inside the block...after I turned off the engine it made a sound of pressure squeezing out of the block and when I turned the oil cap you could hear the pressure being quickly released. I replaced the oil filter and changed the oil and I even added some seafoam to clean out the engine.
Does anybody have an idea what the issue could be with the pressure inside the block?
lev (03-21-2022)
