problem finding right idle air control valve for 740
I have a 1991 volvo 740 which is a non turbo. It has not idled for months due to a failed control valve. It seems no matter where i go to they want to send me the wrong version or a new version which is the one you see on the right side in my pictures. Anyone seen the version on the left in my pictures for less than the 130 to 400 range? I cant seem to find an unused one and a lower priced one that is my stock version. Who else has run into this problem and anyone got any background info on it?
Also anyone know what volvo i could snip connectors off of for the iac on the right?
![](https://volvoforums.com/forum/attachment.php?attachmentid=11751&stc=1&d=1432338788)
Does your car have the Bosch fuel injection? I'm curious as I have an IAC (aka ISV) from an older Audi on the shelf which I'd send you if you'd like to try it (Bosch) PN 0280140505 - I think the 740s use PN 0280140516 but they look darn similar to me - (3 prong connector, 90 degree input/output angle). BTW, your pictures/attachments won't open on the forum - you may have to post to a photo album first. Also, did you try cleaning out the IAC with some carb cleaner and reinstalling? Clean it out and plug it back in - you should feel the motor vibrate when you turn on the car.
You guys cant see my pictures? I can see them viewing the thread even when imnot logged in. Ill try to find more pics but my iac doesnt say Bosch and im not sure if i have their injection system.
i did use carb cleaner and break fluid and we got some idle but that quickly fell off. If i can get a good reliable interchange source id be in business since volvos are either always slim pickings at my junk yard or they have 20 but they are all completely different models smh. Thats a consistent problem. If you are saying that saab iac will work ill try to track those down. Have you known them to interchange or do you just know their connectors are identical? Whats n/a?
Volvo 740 940 Rex Regina Idle Air Control Valve IAC Motor | eBay
I got that one.
Everyone i have ordered the part from wants to send me the one in the link below
GEGT7610 324 Idle Air Control Valve Fits Alfa Romeo Saab Volvo | eBay
I got that one.
Allegedly if you splice a bosch wire pigtail, the bosch iac will work on the regina system.
https://www.brickboard.com/RWD/volvo...egina_car.html
In future, mention that your car is a regina 740; helps.
#18
As per a previous thread of his, it *should* be a known. I wrote that so the OP would know to include salient details about the car in the future.
#19
Id tried to find out in the past if it was regina or not and found no evidence to verify or reliable info on that volvo variant.
![](https://scontent-ord1-1.xx.fbcdn.net/hphotos-xat1/t31.0-8/11288948_10153223204655901_4179117902256169063_o.jpg?efg=eyJpIjoidCJ9)
I cant even get the new iac to work in this vehicle even though it works when i hook the iac to a battery or jumper. Does anyone know which relay controls the iac or the terminals on the ecm that i can test?
