Problems with the instrument cluster and power windows.
Old 03-31-2012 | 04:41 PM
SCHTAAD's Avatar
All I gotta say is that the instructions that Burn Stains provided were totally what I needed.
My drivers side window was not going up but, able to go down.
Follow his instructions step by step and you won't have to spend any $$ for this fix.
Thanks a ton!
  #22
Old 04-01-2012 | 09:28 PM
Burn Stains's Avatar
Glad we could help, and thanks for doing your part and using the search function.
  #23
Old 01-01-2016 | 10:39 AM
alleycat333's Avatar
WOW. GREAT stuff here. My dilema is not listed anywhere I looked, My tempature gauge did not work along with my odemeter. I bought a new piece for the odometer the gear was broken and I bought the sensing unit for the temperature gauge and replaced that too. When put back in odemeter and tempature gauge still did not work. Now the gas gauge was reading half when full. Reading previous posts it suggested cleaning the connections. After doing this speedometer and fuel gauge stopped working. I notice my charging light now glowing but not fully on. High beam blue light works but the lights that came on by turning key do not now. When I cleaned the inside of the plugs going to cluster ( the brown heavy plastic) with a brass brush I heard the key alarm slightly ring then disconnected battery. No sparks. Is there anything that would go in common with these issues ?
AnEskimo
06-25-2019 06:04 AM
mjohnny
03-18-2013 02:35 PM
tommckenzie
08-08-2012 06:02 PM
Silver_S80
12-01-2009 04:13 PM
Quick Reply: Problems with the instrument cluster and power windows.
