question about the idle stabilizer 1986 car
Old Nov 26, 2014 | 12:44 PM
alfaromeo's Avatar
Question question about the idle stabilizer 1986 car
how does this work, doe's it need a pick up point of the coil? I have changed my igniton to a stand alone hot spark system.thanks... note....... doe's it work off the throttle switch? i.e.org wire?
Old Nov 26, 2014 | 05:35 PM
TIPSP's Avatar
Got Boost?
Here is a list of diagrams from a 86 240 model: http://www.volvowiringdiagrams.com/v...240%201986.pdf
Page 19 has the engine parts. look for idle valve. It's near the center of the page.
Check out other diagrams: Volvo Wiring Diagrams=
Old Nov 26, 2014 | 10:50 PM
the volvo ICU (Ignition Control Unit) sends timing pulses to the ECU (fuel injection control unit), the ECU tracks the engine RPM and timing from these pulses.
the ECU runs the idle air controller as well as the injectors, and also the fuel pumps
Old Nov 28, 2014 | 04:34 PM
alfaromeo's Avatar
I guess the point it the FI ecu that runs the idle stabilizer get a 'NEG ' signal from the the igniton ecu or can it get the same 'NEG ' signal, from the coil.. or ahs anyone here put lh2.2 jet on a older Volvo and not used the stock EZ ignition that comes with lh jet cars.
Old Nov 29, 2014 | 02:53 PM
the timing pulse into the ECU comes directly out of the ICU, its /not/ the same signal as the coil power pulse. I've not stuck an oscilloscope on it, but its likely a TTL 5V pulse, rather than the 12V power pulse that goes to the coil
alfaromeo
Mar 20, 2014 12:17 AM
Rakam
May 27, 2011 09:03 PM
Scott6
Sep 15, 2008 06:20 AM
tolliver
Nov 23, 2007 12:32 PM
ludeless
Jun 4, 2006 02:58 PM
