Rally volvo
Old Feb 22, 2010 | 03:06 PM
Millhouse118's Avatar
Default Rally volvo
Hey everyone! Im new to the volvo community and looking into rallycross/ rally (eventually) I just picked up what i believe is a 84 240...not 100% sure so if somone corrects me that would be awesome! But i was just wondering if anyone had any pointers in which direction to head? Im shooting for Production class maybe G2? like i said thats eventually but i work in the body shop field so i know i will have to do some rust repair before anything happens but its a 5-speed non-turbo i believe so i will probably be looking into the turbo engine upgrade. But if anyone has any pointers just let me know all help is appreciated! Thanks again! Here is a pic of the old girl...shes raring to come back to life!
Old Feb 22, 2010 | 06:06 PM
adub96's Avatar
That pick axe buried in the trunk is good for a few extra ponies. All kidding aside good luck a turbo engine upgrade would be a good idea. JovhV the outside agitator and towery on turbobricks both have rally 242's
Old Feb 22, 2010 | 06:16 PM
Somthngfrce's Avatar
Nice Axe! I hear that helps with aerodynamics... Welcome to the forum
Old Feb 22, 2010 | 10:21 PM
TIPSP's Avatar
Got Boost?
probably a 78 242DL
Old Feb 22, 2010 | 10:40 PM
Hey thanks for the help guys. I think the axe was an option that year? I cant complain to much it was free! I will PM the guys you told me about and get some pointers. Once construction begins i will try and post pics.
Old Feb 22, 2010 | 10:53 PM
TIPSP's Avatar
Got Boost?
well, johnV sells rally coilovers, and so does RSI.
2.0liter turbo motor, humm. time for rsi to sell their rally storker kits.
good luck! this has some cool ideas.
Old Feb 23, 2010 | 01:34 AM
Typhoon's Avatar
I always thought the 16 valve engine in a lightened Volvo would go pretty well non turbo.
Thought about building a hillclimb 740 like that, use a base model 740 GL, strip it out etc...
Regards, Andrew.
Old Feb 23, 2010 | 02:36 AM
TIPSP's Avatar
Got Boost?
that would be pretty sweet Andrew!
Do it! or are you saving to build a towing 740....
Old Feb 23, 2010 | 12:45 PM
Thanks again for the support and help on the parts. That was the thing i was worried about most was finding a good setup for suspension. That really helps abunch!
Old Feb 24, 2010 | 01:10 AM
Typhoon's Avatar
Oh, I'll do it! Just waiting patiently for the right, cheap cars/parts to come along.
I've also been looking into Mitsu V6 engine swaps, they are very cheap engines with a great broad torque curve and great peak power.
Regards, Andrew.
Old Mar 1, 2010 | 08:37 PM
Went and watched the 100AW rally this past weekend and saw the rally 242. Took abunch of pictures of it so i got some good ideas! He had a little more money in his than i want to put in mine but i know which direction to head in. So hopefully go pick up my brick this weekend and get started on it.
Old Mar 1, 2010 | 08:57 PM
89turbo's Avatar
a 16v engine base or turbo engine is a good swap suspention ipd springs and ipd anti-sway bars u can check it out on ipd.com and check out on ebay the rear tail lights u can use the later 240 ones if u cut about an inch will fit and do not worry about the plug it will work p.d on ebay u can find a lot stuff so u can put your 242 on road nicely
Old Mar 3, 2010 | 09:22 AM
cbevis's Avatar
http://www.kaplhenke.com/index.php makes some pretty sweet mods for the 240 series. I don't know that I'd use their coilover setup for rally....more of an autocross kind of design I think....but the rest of their adjustable suspension stuff would come in handy.
Old Mar 3, 2010 | 03:02 PM
That looks like some pretty good stuff like you said maybe not alot for rally but some stuff would be nice. The thing im finding out now is the safety stuff, well not all of it just the dang hans device. Jeeze 600 for the cheapest model thats insane! but i gotta have it, im planning on scoping ebay for awhile and if nothing turns up just forking out the cash but oh well, ive been hearing about a tail light problem with volvos whats that all about? is it something to worry about while rallying since i have to have all lights functioning?
Old Mar 3, 2010 | 05:04 PM
cbevis's Avatar
the tail light problem stems from crappy connectors to a terrible design for bulb connection. Pull it apart and you'll see what I mean. Most folks with issues just rewire everything to eliminate the the flimsy circuit board and wire connector. Everything is color coded back there....makes it a little easier IMO.
Old Mar 4, 2010 | 07:53 AM
adub96's Avatar
Kaphlenke is sooooo over priced. I would talk with the yoshifab guys and RSI they're more rally and budget oriented.
Old Mar 4, 2010 | 08:23 AM
  #17
cbevis's Avatar
it's easy to call out overpriced when it's 4130 TIG welded and nickle plated aluminum. In fact, statistically, their coil over suspension is on par with Tein's Euro Dampener (that starts at $2k).
good parts aren't cheap.
Old Mar 4, 2010 | 12:32 PM
  #18
ok so the tail light thing doesnt sound to bad. as far as suspension goes until i get pretty good and have a decent budget im gona go with some bilstein HDs just to start out no need to go full bore on a coil over system to wrap the car around a tree the 1st time out. Besides gotta save my money for all the safety equipment.
Old Mar 4, 2010 | 01:16 PM
  #19
cbevis's Avatar
true that ^
Old Mar 4, 2010 | 02:05 PM
  #20
TIPSP's Avatar
Got Boost?
RSI is not budget friendly either.
The cheapest route is to build it your self.
