Rear end swap question
I had a nice '89 240 Wagon till last month when my son totaled it in an accident. I found a reasonably good '91 240 Sedan that was dirt cheap and am using the '89 as a parts source to get the 91 back up and running.
Once concern I had about the '91 is that the rear differential had a leak so I am worried that it may be worn. The '89 was in good shape and I know the history behind it so I was considering swapping the whole rear end from the 89 into the 91. The question is, is there any difference in rear-end ratios that I need to be concerned about (like incorrect speedometer readings)? Also, is this a big job? At first glance, it seems to be fairly straightforward to swap. Any advice would be helpful. |
RE: Rear end swap question
(w/speed sensor), 3.31 ratio
(w/speed sensor), 3.54 ratio (w/speed sensor), 3.73 ratio 1987 Rear Axle Volvo 240 DL,CHK COND 050296 Mossy Head Auto Parts USA-FL(Crestview) E-mail 1-850-892-5333/1-800-892-6017 767 1990 Rear Axle Volvo 240 (w/spd sensr), 3.31 ratio- 135,000 A 01-233 French's Auto Parts, Inc. USA-VA(New-Market) E-mail 1-800-443-1303 225 1990 Rear Axle Volvo 240 (w/spd sensr), 3.31 ratio- guessed-UJA 199,000 A 14521 Abcat Auto Salvage USA-MI(Ypsilanti) Request_Quote 1-800-869-6933 Request_Insurance_Quote 134 1989 Rear Axle Volvo 240 3.31 ratio- 227,000 C LG003 Erie Vo-Vo, Inc. USA-NY(Whitesboro) E-mail 1-888-865-8613 345 1991 Rear Axle Volvo 240 CK RATIO 118,000 A 000633 Davidson Auto Salvage USA-NC(Lexington) E-mail 1-336-956-1219 1-800-365-8098 373 1984 Rear Axle Volvo 240 CHECK ID,1429039 218,752 |
I don't need another rear axle. I am trying to find out if the one I have (from an '89 240 DL Wagon) is a straight up replacement for a '91 240 Sedan.
ORIGINAL: act1292 I had a nice '89 240 Wagon till last month when my son totaled it in an accident. I found a reasonably good '91 240 Sedan that was dirt cheap and am using the '89 as a parts source to get the 91 back up and running. Once concern I had about the '91 is that the rear differential had a leak so I am worried that it may be worn. The '89 was in good shape and I know the history behind it so I was considering swapping the whole rear end from the 89 into the 91. .................................................. .................................................. .......................... The question is, is there any difference in rear-end ratios that I need to be concerned about (like incorrect speedometer readings)? YES (like incorrect speedometer readings)? (w/speed sensor), 3.31 ratio (w/speed sensor), 3.54 ratio (w/speed sensor), 3.73 ratio year range that will fit your 1991 240 is 1984 Rear Axle Volvo 240 - CK RATIO 1991 Rear Axle Volvo 240 - CK RATIO .................................................. .................................................. ...................... Also, is this a big job? At first glance, it seems to be fairly straightforward to swap. Any advice would be helpful. |
| All times are GMT -5. The time now is 12:57 AM. |
