Rear Wheel Bearings Replacement Cost (1993 940)
Old Apr 14, 2021 | 06:23 PM
YogiBear200's Avatar
Default Rear Wheel Bearings Replacement Cost (1993 940)
Hello everyone,
I just picked up a 1993 Volvo 940 (Base) and it needs some Suspension work.
It looks like a lot of the bushings and the tie rods needs replacing, along with the rear wheel bearings.
Does anyone know how much a fix like that should cost?
Thanks,
Yogi
Old Apr 14, 2021 | 09:00 PM
Rear wheel bearings? on a live axle? Why?
Old Apr 14, 2021 | 09:03 PM
there is a little squeak and a left to right movement of the wheel in the rear.
Old Apr 14, 2021 | 09:12 PM
If the wheel bearings were allowing left to right movement - That would push the brake pads back, and the discs would rub against the calipers - in turns i guess (the calipers are fixed to the diff housing) - and cause the brake pedal to be very soft. Is that happening?
If so you would be able to see grinding marks on the brake discs where they were touching the calipers.
bartowd
Jul 29, 2018 08:13 AM
dfera
Oct 17, 2015 03:34 PM
allenot1
Jun 8, 2015 08:37 PM
ewofnich
Jun 15, 2014 04:13 PM
940turbo94
Nov 29, 2007 09:39 PM
