Rough idle 245
Hello, Irecently purchased a 79 245 with Bosch injection from the original owner ( a friend) 222,000 miles, timing belt changed at 216,000.
It had been sitting for 4 years. I drained all the fuel, added inj. cleaner, changed the fuel filter, plugs, rotorand cap. It seems to run ok at higher rpm but idles very rough.
Also the clutch is very difficult to depress. Any ideas?
Thanks,
William
Thanks,
William
There is an "idle motor" that is attached to the cam cover with two bolts (I think they are hex head cap screws). It has one electrical plug and two hoses attached. When you take it off you will be able to look down the hose holes and see the shutter inside. Clean this with spray cleaner. the computer adjusts the opening and closing of the shutter to adjust idle air.....
nkinkade
Feb 28, 2014 08:49 PM
dcwave
Nov 27, 2012 09:56 AM
Volvo240Rookie
Oct 15, 2010 07:48 AM
