rough ilde
Old Apr 8, 2005 | 10:01 PM
wavewright's Avatar
Default rough ilde
new to volvo. i read about air mass meter causing problems, unplugged it, it ran better. replaced amm, still idles rough. also blows black smoke when you give it alot of gas,and has a strong gas smell. help! ps there is a wire ( 2 wires orange blue/white blue connector) that run in the same harness as amm wire that is unpluged and i cant find where it would plug in.
Old Apr 8, 2005 | 10:37 PM
Default RE: rough ilde
You are running very rich for some reason.Check the O2 sensor.Also clean the throttle body and idle motor.
Old Apr 8, 2005 | 10:49 PM
wavewright's Avatar
ok how and where on the O2 sensor and idle motor. sorry im new at this.
Old Apr 9, 2005 | 01:24 AM
The idle motor is located under the intake manifold.It looks like a cylinder with 2 hoses going to it.It also has a plug going to it.
Im not sure what year or exact type it is.Look on the passenger side the older cars have a green wire for the O2 sensor.Where it plugs in there is a spade connector.It is plastic on one sdie and a rubber boot on the other..Using a Volt meter put the positive lead on the green wire.Then put the other to ground.Once the car is warmed up the voltage should move up and down.From 0 volts to 12 volts.If it doesn't it is bad.
v70 2.4t
Sep 20, 2005 01:35 AM
proudmonkey
May 20, 2005 10:49 AM
duffdr
Apr 12, 2005 01:51 AM
Tech B
Oct 28, 2004 09:34 PM
billder
Aug 8, 2004 12:01 AM
