Shifter light bulb change
RE: Shifter light bulb change
I have the '90 740 GLE. I was able to replace it by removing the fuse cover, popping the center consol clip under the fuse cover, removing the two screws in the center consol an removing the center consol. Once it was out of the way I had to unscrew the shifter cover and the bulb was on the underside of it. Works like a champ now!
hey zon.... thanks for the advice... i removed the ashtray/fusebox/storage box and the two phillips screws at the bottom of the center console near the parking brake. However, I'm a little uncertain on how to get the automatic shifter cover off. and also, do i need to remove the hard to reach torx screws on the metal brace near the fusebox?
ORIGINAL: ivrylineslead
There are just 1 or 2 screws holding on the cover, cant remember for some reason. But anyhow it was pretty obvious which screw(s) held it on. The screw(s) were right next to the P R N D 2 1 display.
xDread92x
07-21-2019 04:18 PM
sandraqu
12-24-2009 02:36 PM
phoenix_iii
01-11-2008 07:15 PM
