Sparkplug choice
Old Jul 21, 2020 | 02:08 PM
Goldenblock's Avatar
Default Sparkplug choice
Curious to see what people have as sparkplugs in their redblocks and also preferred heat ranges!!!
Goldenblock
Old Jul 21, 2020 | 02:19 PM
I nearly always used Bosch Super 7900, aka WR7DC, or NGK BPR6ES
these engines aren't very fussy., but 'platinum' or 'iridium' plugs are a waste on them, they are happier with old school copper plugs.
Old Aug 1, 2020 | 11:38 PM
Sambar Stag's Avatar
Just as Pierce said, the copper plugs work just fine on these engines. I, however use the Bosch WR6DC in my car now. It is a plug 1 step cooler than the aforementioned stock WR7DC. It helps to prevent the knocking I sometimes get in hot weather when the A/C is on. I changed to that range in the hope that it (and some other things) would help my NOx emissions in trying to stay good with the CA. Smog checks. It has worked.
Old Aug 2, 2020 | 01:30 PM
plug temperature ratings are often misundertstood.
a 'hotter plug' is able to dissipate more heat so it runs cooler, this is suitable for a hotter engine. a 'cooler' plug has less heat dissipation capability, so it runs hotter, better for a cooler engine as it keeps deposits from accumulating.
many car engines spec a hotter plug in Europe than they do in the US, as highway speeds are higher, so the engines are running higher RPMs. Americans seem to like their engines running barely above idle.
92Typhoon
Sep 11, 2020 06:09 PM
gpjlytham
Oct 1, 2018 09:50 AM
tahafisaka6
Aug 7, 2010 10:31 PM
drdave2021
Nov 10, 2009 06:33 PM
nandrolone
Oct 13, 2005 01:44 PM
