Speedometer Drops to Zero
Just bought my first Volvo yesterday, a Black 940 GLE Turbo. It has 240,000 miles on it, but with a completely rebuilt engine and transmission. And the speedometer stopped working. Well, actually, it didn't stop working completely. It is on zero most of the time, but every once in a while, it jumps up to the correct speed. But then it falls back down to zero and stays put. 98% of the time it's on zero.
Anyone have this problem before? Any help would be greatly appreciated.
In the rear diff. cover there should be a sensor with 2 wires going to it.Yhat is the speed sensor for the ABS and for the speedometer.
Check the wiring first then check the sensor.
ORIGINAL: tech
It's gonna be a PITA to find a 940 Turbo speedo cluster around here.
Aloha everyone. I just bought a '92 940 Turbo and I have the same problem as mentioned in this post - the speedometer is intermittant. It will be working and then it will drop to zero and then maybe a few minutes later it will start working again. Same symptoms as in the original post. I will check my rear differential and the connection there, but in the meantime... I am interested in finding out weather the solution to the problem was discovered, and how it was fixed, by zysoclaplem.
Any help would be greatly appreciated. Mahalo, MikeO
ORIGINAL: zysoclaplem
krisb410
Sep 29, 2012 11:21 AM
