Squirter line discon
89 240, the washer hose must have broken, become disconnected, up inside the hood. Blankity blank thing! when I hit the switch it rains blue on the engine! Anyone ever had this? cant see in there! Jeeze! Dave
take off the hood shield....any pics of this?
never happened to me..... |
Pop your hood and check near the dash. You should see two hoses running up into the hood. These hoses are then connected to plastic/metal clips which sit in your hood to direct the spray. If one of them is dangling check the loose end. If there is a chunk of plastic or metal inside of it, you have a broken clip.
If thats the case, you should be able to get the busted clip out easily with a flat screwdriver, bring it to a volvo dealer and order the replacement clip. It costs about 6 dollars. Once you've got the new clip just pop it into the hole, attach the hose and you'll have a working windshield sprayer. |
squirt
Good, got it- we're washin!
