Squirter line discon
Old May 8, 2009 | 03:56 PM
daver80's Avatar
Default Squirter line discon
89 240, the washer hose must have broken, become disconnected, up inside the hood. Blankity blank thing! when I hit the switch it rains blue on the engine! Anyone ever had this? cant see in there! Jeeze! Dave
Old May 8, 2009 | 04:01 PM
TIPSP's Avatar
Got Boost?
take off the hood shield....any pics of this?
never happened to me.....
Old May 11, 2009 | 11:18 AM
hogbrained fool's Avatar
Pop your hood and check near the dash. You should see two hoses running up into the hood. These hoses are then connected to plastic/metal clips which sit in your hood to direct the spray. If one of them is dangling check the loose end. If there is a chunk of plastic or metal inside of it, you have a broken clip.
If thats the case, you should be able to get the busted clip out easily with a flat screwdriver, bring it to a volvo dealer and order the replacement clip. It costs about 6 dollars. Once you've got the new clip just pop it into the hole, attach the hose and you'll have a working windshield sprayer.
Old May 11, 2009 | 01:20 PM
daver80's Avatar
Default squirt
Good, got it- we're washin!
johnwartr
Apr 22, 2013 10:04 PM
pezwack
Nov 7, 2011 05:42 PM
defuse
Aug 3, 2005 09:41 PM
mm3_terry
Jul 21, 2005 11:36 PM
guptash
May 1, 2005 08:58 PM
