Starter Noise On Startup
Every time I start the car I hear a whining or chatter noise for about 1-2 seconds. Someone suggested this might be the starter bendex that is spring loaded. I have lived with it for a year and it has not gotten worse.
Eventually, what will happen? Could it cause the starter to stay on and somehow damage the flywheel? Is the fix a new starter? thanks |
RE: Starter Noise On Startup
Oh - the car is a Volvo 240DL, 1990 with manual transmission
You will need a new starter.
I've just installed a newly rebuilt BOSCH starter and w/ignition key on, it makes the whining noise the previous post described, as if starter gear is not engaged.
Do I have another bad starter? What else could cause such noise? Is there anything else I can try before I uninstall the unit and take it to AutoZone for bench test? Thanks for your time! 96 Volvo 850 Turbo - 126K miles |
