Starter Noise On Startup
Old Dec 12, 2005 | 01:25 PM
jdbs3's Avatar
Default Starter Noise On Startup
Every time I start the car I hear a whining or chatter noise for about 1-2 seconds. Someone suggested this might be the starter bendex that is spring loaded. I have lived with it for a year and it has not gotten worse.
Eventually, what will happen?
Could it cause the starter to stay on and somehow damage the flywheel?
Is the fix a new starter?
thanks
Old Dec 12, 2005 | 01:30 PM
jdbs3's Avatar
Default RE: Starter Noise On Startup
Oh - the car is a Volvo 240DL, 1990 with manual transmission
Old Dec 12, 2005 | 09:17 PM
You will need a new starter.
Old Feb 3, 2009 | 05:11 AM
mygreat850turbo's Avatar
I've just installed a newly rebuilt BOSCH starter and w/ignition key on, it makes the whining noise the previous post described, as if starter gear is not engaged.
Do I have another bad starter? What else could cause such noise?
Is there anything else I can try before I uninstall the unit and take it to AutoZone for bench test?
Thanks for your time!
96 Volvo 850 Turbo - 126K miles
rj0828
Dec 27, 2009 10:45 AM
iluvmyS60
Jun 9, 2009 07:18 AM
850owner12
Dec 10, 2007 05:51 AM
94_850T
Dec 9, 2007 07:18 AM
wheelsup
Dec 7, 2007 12:00 AM
