starting problem
Sometimes when starting my 89 740 auto wagon the car will sputter and not start. Then it will just crank and crank, but not start. If i wait about 10 minutes, it starts right up and is fine. This happened 2X today, and now it doesn't start or so says my son that has the car. It is about 95 out with 90% humidity. Could it be vapor lock or a flooding problem sometimes? I never have problems otherwise like stalling, bucking, power loss or anything.
Any ideas?? Thanks
Any ideas?? Thanks
radio suppression relay powers the injectors. be sure to tell your son no gas, foot off acclerator when starting. fuel injection cars like to figure it out for themselves. The volvo fuel injection is very tolerant but it is possible to flood engine if you use gas when starting. This is absolute starting death with my mazda miata. NEVER BUY A MAZDA! After two engines with thrust bearing problems, clutch shudder, failed coil pack, precat failure, etc and no help from mazda I hate them! I hate them! This on a car with 25,000 miles. I bought my volvo back (it has 250,000 miles) and have been happy about it ever since! Sometime I will tell you how I really feel (I hate them!)
Thanks Wojeepster - I am a novice so bear with me. Granted my radio antenna no longer goes all the way up, but on AM, i can barely hear anything do to severe static that mimics the engine revs. Could that be a sign of a bad radio supression relay, or am I way off??? Thanks
You can get a antenna mast so your antenna will go all the way up once again. Static on radio is likely caused by failing plug wires.
http://fcpgroton.com/volvo240other.htm
rideagiant
Sep 10, 2009 07:56 AM
