starting problems
Old Dec 21, 2014 | 10:46 AM
asking questions's Avatar
Default starting problems
i have a 91 740, i have replaced the fuel pump, fuel pump relay, fuel pressure sensor ,air temp sensor,map sensor, o2 sensor, distributor cap and rotor button. it has a regina ingition system. it will turn over but will not start. please advise what them problem could be..... I have all but given up
Old Dec 21, 2014 | 12:32 PM
thats a lot of parts to replace without doing any diagnostics.
to start, you need compression, spark, and fuel. you need to figure out whats missing.
Old Dec 21, 2014 | 03:17 PM
brickrunner's Avatar
It could be your crank positioning sensor or your ignition control module, but do what Pierce says because if you don't you will keep replacing parts and throwing money out the window.
Old Dec 21, 2014 | 03:30 PM
failed CPS == no spark *or* fuel
past that, I dunno, I have zero experience troubleshooting regina systems, I've never even seen one up close.
Old Dec 24, 2014 | 10:23 AM
act1292's Avatar
Also check your timing belt. Remove the oil cap and peek inside while a friend cranks the engine. If you don't see the cam moving then your timing belt is broke.
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
bccb037
Dec 29, 2004 04:42 PM
rl92821
Feb 1, 2004 12:54 PM
