Starting Problems
Old Oct 22, 2006 | 06:06 PM
sirjinx's Avatar
Default Starting Problems
My 940 turbo has issues starting in the morning from a "dead start", it makes this loud annoying noise like theres something wrong with the belt(s) but the belt(s) is/are fairly new, like 6 months old. So my question is, could there be something else making that noise or is it without a doubt the belt(s), also does anyone know what belt(s) start moving/spinning when you first start the car?]
Thanks,
Jay
Old Oct 22, 2006 | 07:18 PM
billofdurham's Avatar
Default RE: Starting Problems
What sort of noise? Is it a squealing noise or a thumping noise?
All the belts should start moving when the engine starts. If one or more don't you have a problem.
Old Oct 22, 2006 | 09:16 PM
sirjinx's Avatar
Thanks, yea its a squealing noise.
Old Oct 22, 2006 | 10:58 PM
fivespeed's Avatar
HI,SOUNDS LIKE YOU HAVE A LOOSE OR SLIPPING FAN BELT. TRY SPRAYING BELT AND PULLEY WITH A SQUIRT OF WD40 OR SIMILAR BEFORE YOU START UP IN THE MORNING. IF THIS STOPS NOISE THEN RETENSION BELT. HOPE THIS HELPS.
Old Oct 23, 2006 | 06:56 AM
Better just to check the tension on the belts than spray with any type of oil.
On the longest run of each belt there should be about 5 - 10mm of downward movement when pressed with a finger at thecentre point of the run.
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
bccb037
Dec 29, 2004 04:42 PM
rl92821
Feb 1, 2004 12:54 PM
