starts, stalls, won't idle
Old May 15, 2008 | 04:57 PM
elementfe's Avatar
Default starts, stalls, won't idle
86 240- sat for a long time, then started right up when needed.
It began stalling at idle, then would only run when the engine was raced or throttle was pumped- it behaved like a carbureted engine that wasn't getting enough fuel: if you tap the throttle, it will keep going, but this one is injected.
Checked the fuel pumps, and it's getting lots of fuel.
It starts, runs for a couple seconds smoothly, then stalls- I can get down the road but it will only keep going at high revs.
Thanks for any ideas!
Andy
Old May 15, 2008 | 11:05 PM
blue goose's Avatar
Default RE: starts, stalls, won't idle
Check the idle air control (IAC) motor. It's supposed to bypass the throttle and provide an air intake when the throttle is closed.
Old May 15, 2008 | 11:52 PM
alexi3rdgen's Avatar
Alternately, it could be an air leak w/ one of the vacuum hoses. I replaced a couple of hoses on mine, and the same thing happened. I then realized that I'd forgotten to reattach one of the vacuum hoses near the intake manifold.
Wes
mollythegreat714
Jun 3, 2015 07:18 PM
Dano-1
Aug 17, 2014 08:15 AM
nkinkade
Feb 28, 2014 08:49 PM
Troi Lynn Whitethorne
Apr 19, 2012 07:10 PM
gary5461
Nov 28, 2005 09:23 PM
