Stick shift vibrating in Reverse
Old Oct 8, 2015 | 07:11 PM
Dagaan's Avatar
Default Stick shift vibrating in Reverse
'86 240 wagon
My stick shift - on an automatic - chatters or vibrates - hard - in reverse. But not in any forward gear. Does the stick shift need re-aligning with the transmission?
Thanks
Old Oct 9, 2015 | 03:59 AM
TIPSP's Avatar
Got Boost?
Check your center drive shaft bushing and transmission mount.
Old Oct 12, 2015 | 02:04 PM
Dagaan's Avatar
Thanks TIPSP -
Your observation sent me under to look at the drive shaft supports and I found that the rear trans shifter - the slave to the front shifter - was knocking against the bolts on the first drive shaft four way connect. I just used a couple of crow bars and bent something so it wouldn't do that!
Old Oct 12, 2015 | 02:05 PM
Dagaan's Avatar
Thanks TIPSP -
Old Oct 15, 2015 | 01:12 AM
if it was moving, its very likely that the transmission mount is shot. this is effectively the rear engine mount too
winston901
Mar 11, 2012 12:51 AM
philbromwich
May 23, 2011 05:42 PM
shadow13
Jan 13, 2011 11:24 PM
volvoist3021
Jul 31, 2009 01:01 PM
postdoc99
Feb 8, 2007 08:00 PM
