stuck in florida
Old Jul 28, 2010 | 10:37 AM
dgrimmautos's Avatar
Default stuck in florida
hello,
i have a 1991 volvo 940 turbo,its been at the repair shop for 2 weeks now,and they cant figure out whats wrong.these guys are european mechanics too!
my car cranks over,but wont start,as of today,i have changed the flywheel sensor,the ingnitor,rotor,cap,coil,the main ECM computer,the ignition computer,the fuel injection relay and they have checked the timing belt.so far no luck...
these guys are stumped as well.i hope someone here can give me some advise.
thank you
Old Jul 28, 2010 | 11:08 AM
tedv's Avatar
Fuel Injection relay? That should have been changed first...
Old Jul 28, 2010 | 11:32 AM
im sorry,i forgot to mention i did that too.im not getting spark
Old Jul 28, 2010 | 08:52 PM
Marauder03's Avatar
did these have the radio suppression relay like the '87 740? looped into the ignition circuit, that is. I remember reading somewhere when I still had my 740 that if this relay blew, it would prevent spark from being delivered. I don't know if the '91 940 turbo is wired the same way or not.
Old Jul 28, 2010 | 10:30 PM
redbottle's Avatar
either they are taking your for a dummy or what??? what do the codes read? they have read the codes I presume? I can't freaking believe they can't figure it out....
Old Jul 29, 2010 | 02:31 AM
volvoguy2323's Avatar
Banned
Check all your engine ground connections first and foremost then check the power stage...if that doesn't work and they've already thrown the kitchen sink at it, you may have a bad engine wire harness....
Old Jul 29, 2010 | 09:09 AM
my radio is an aftermarket CD player and its been in the car for some time now.ill have them check for that relay though.
Thanks
Old Jul 29, 2010 | 09:12 AM
this all started when i brought it in for a water hose leak on the back firewall,they removed the heater control valve and blocked off the hoses.we dont need heat here in florida.when he was done with that,the car would not start up again.i have check for corrosion on all the plug-in relays and connectors thinking something got wet,still nothing..
Old Jul 29, 2010 | 12:10 PM
Banned
maybe he broke or loosened the main ground?? Have them check all your grounds if they were doing work back there....
Obelix
Jun 20, 2022 08:40 AM
amotin
Dec 12, 2008 09:13 PM
tech
Nov 13, 2007 11:51 AM
05S40BE
Sep 23, 2007 05:32 PM
