In-tank fuel pump
Old Dec 14, 2007 | 11:09 AM
act1292's Avatar
Default In-tank fuel pump
I have a '91 240 that the gas gauge was broken. When I went to check the sending unit, I found that the wires at the gas tank were no longer connected due to rust, etc. at the tank. The car still ran fine. I replaced the tank with one from my '89 240DL and things are fine.
Is there an in-tank fuel pump on these? I always thought there was but since my '91 ran fine (no symptoms at all) without any wires connected to the tank, I began to question whether it has an in-tank pump (there are only 2 wires) or whether it does much.
Old Dec 14, 2007 | 11:31 AM
MHUSTON's Avatar
Default RE: In-tank fuel pump
I AM NOT SURE IF THIS WILL HELP OR NOT BUT I HAVE AN 86 240DL. WHEN I REMOVED THE ACCESS PANEL ON MINE THERE ARE TWO SETS OF WIRES BUT THE ONE THAT GOES DIRECTLY TO THE TANK HAS THREE WIRES ONE GROUND AND I GUESS ONE FOR THE GAUGE AND ONE FOR THE PUMP. AT THE SAME TIME I HAVE RAN TESTS ON MINE THAT BYPASSED THIS PUMP. AND IT STILL STARTED AND RAN FINE I BELIVE IT IS MORE OF A HELPER PUMP TO RELEIVE SOME STRAIN ON THE MAIN PUMP.
Old Dec 14, 2007 | 03:34 PM
act1292's Avatar
Thanks for your input. I guess I really won't worry about it working or not as the car starts and runs fine.
Old Dec 15, 2007 | 12:56 AM
rene's Avatar
My 86 240dl lost the main pump because the in tank pump failed. The main may have taken a while to fail. The mechanic said main pump needs the in tank pump to operate properly. Cheers
Old Dec 17, 2007 | 08:39 AM
act1292's Avatar
Well, I did replace the entire gas tank. Hopefully the new tank's pump is working. Anyone know how to tell if the in-tank pump is working? I can hear the main fuel pumpbutnot anything from the tank.
Old Dec 20, 2007 | 10:12 PM
kcm270's Avatar
If the in tank pump is not working, you'll notice a significant loss of power at speed. If it seems to have normal pick up, you're doing fine.
Old Dec 21, 2007 | 08:24 AM
act1292's Avatar
Actually, my wife and daughter complain that the '91 doesn't seem to have the pickup that our old '89 wagon used to have. However, I think this is off the line and at lower speeds. It seems to do better at higher speeds (40-50mph).
I have had the '91 up to 70-75 and haven't noticed anything abnormal about the way it runs. When you say a loss of power, do you mean it will stumble when accelerating at high speeds or generally run bad?
Thanks for the help
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
AnEskimo
Oct 7, 2010 07:28 AM
skyrider20
Nov 29, 2008 07:01 PM
