temp?
Old Sep 22, 2015 | 12:57 PM
bigarms23's Avatar
Default temp?
i have a 88 240DL i recently replaced the upper and lower radiator hoses and upon first start up the temp gauge will run normal then spike up for 25 seconds then go back to normal what would cause this i did order a new thermostat last night
Old Sep 22, 2015 | 01:19 PM
probably the compensator circuit thing on the temp gauge is out of whack, totally coincidental to your work
Old Sep 25, 2015 | 11:09 AM
REVOLV's Avatar
Give the dashboard some acoustic tuning (smack the crap outta it) and see if any change. My temp guage is flaky right now after cluster swap. Could be that I lost tension on the pins for comp board. I pulled it. Worked fine before. Havent even put a temp guage on the engine because I know its fine.
cc sbrider
Sep 27, 2014 03:16 AM
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
vcolper
Nov 1, 2006 10:20 PM
