Thermostat
How often do you change thermostat on 940, 1995? Also, coolant level drops
about 1" every 10 days. Is that normal (same car)? |
Seldom, if ever..check the other post on radiators..Is the car running hot?
One way to check the thermostat is to put it in a pot of water on the stove and see what temperature it opens. However, by the time you go all the way to the store to get the new $3 seal to put the old thermostat back in, you might as well spring the extra ten bucks and get a new thermostat that comes with the seal. |
Generally recommended to change the thermostat whenever changing the water pump. The coolant level should not drop 1/2" in 2 years.
