Thermostat
Old Feb 6, 2009 | 06:41 AM
LESLIE's Avatar
Default Thermostat
How often do you change thermostat on 940, 1995? Also, coolant level drops
about 1" every 10 days. Is that normal (same car)?
Old Feb 6, 2009 | 03:36 PM
soundmiami's Avatar
Seldom, if ever..check the other post on radiators..Is the car running hot?
One way to check the thermostat is to put it in a pot of water on the stove and see what temperature it opens. However, by the time you go all the way to the store to get the new $3 seal to put the old thermostat back in, you might as well spring the extra ten bucks and get a new thermostat that comes with the seal.
Old Feb 6, 2009 | 03:43 PM
blue goose's Avatar
Generally recommended to change the thermostat whenever changing the water pump. The coolant level should not drop 1/2" in 2 years.
robert213
May 30, 2006 03:23 PM
cameron
Feb 8, 2006 06:06 AM
Eric
Jan 11, 2006 11:43 PM
Buck
Aug 23, 2005 09:20 AM
jcmartin
Mar 1, 2005 01:46 PM
