Throttle Wont Open?
Old Aug 8, 2023 | 07:34 PM
Reed Guy's Avatar
Default Throttle Wont Open?
The engine still idles, drives in idle, and the cables appear to be moving, but the engine gets no gas when I press the pedal or turn the pulley manually. Any ideas? Thanks.
Old Aug 8, 2023 | 11:31 PM
Psaboic's Avatar
Butterfly not moving in the Throttle body? I would pull the throttle body and see what is going on?
Old Aug 8, 2023 | 11:49 PM
Reed Guy's Avatar
Default solved
The little cable that connects the throttle to the pulley unscrewed itself and fell ouf. Randy Sutherland on facebook noticed in a video i posted. Now I just need to find one. Thanks.
Old Aug 9, 2023 | 08:44 AM
If it's the link pictured below that falls off when someone does not tighten the locking nuts after being adjusted - you will need the two lock nuts also - one of those is left hand thread. I think there are 2 different lengths of rods - not knowing what car/engine you have that may not be the correct part number
ChuckB
Jun 4, 2020 02:07 PM
tgaulkin
Nov 27, 2013 03:29 PM
parbar
Dec 5, 2012 02:04 PM
benisasome101
Nov 25, 2008 07:08 AM
Old740
Jul 15, 2008 08:15 AM
