TPS switch leads to greater mysteries
Old Jan 3, 2009 | 12:48 PM
montysano's Avatar
Default TPS switch leads to greater mysteries
So: on my 90 240, I suspected that my idle air motor was not engaging; the idle was always a bit low. I tested it; it was fine, but if I unplugged it, there was no change in idle.
Per Bentley, I next tested the terminal #2 of the TPS for continuity to ground at idle (which is what energizes the idle motor, yes?); no continuity. Must be a bad TPS, I think, so I replace it. Still no continuity to ground at #2.
Here's where it gets interesting: I unplug the TPS. I disconnect the throttle linkage. So now, the throttle valve should be closed and no way the idle control motor is working, right? The car starts and idles fine.
Next, I unplug the MAF. The car starts and idles fine!!! Per Bentley, I test the MAF. Tests as it should.
Other than a low idle, the car has been performing at it should: starts instantly, good power, cruises at 80 mph all day.
I'm stumped [8D]
Old Jan 3, 2009 | 08:10 PM
Default RE: TPS switch leads to greater mysteries
If the throttle body is not adjusted properly then the switch will not function properly either.
The TPS should click when you bairly move the throttle. If not then the switch isn't adjusted properly not allowing the idle motor to work.
Also if the rod is misadjusted then the switch might not be working either.
dbouley
North East
Aug 23, 2015 11:52 AM
PNW
West
Feb 10, 2015 11:18 PM
f88
Mar 9, 2011 08:01 AM
mark_disfree
Sep 15, 2009 05:24 PM
kcw12
Jun 10, 2008 08:48 PM
