trans tune (seafoam) to free up overdrive unit
Now before anyone asks if I checked the solenoid and switch wiring, yes. I get a audible click at the solenoid. I've pulled, cleaned and swapped out solenoids with others around the shop, bench tested. Took off the OD sump and cleaned the filters.
Prior to it not working it would engage harshly/erratic. Now it does nothing. I'm not super familiar w/ how the OD unit works, but I was thinking of trying some trans tune in the tranny.
Do we assume you checked the OD relay?
assuming you're talking about the external OD on a M46/M47 stickshift car...
these overdrives are really underdrives, when the "OD" is off, the OD unit acts as a planetary reduction gear... when you switch the OD 'on', it locks it so its 1:1... it uses a clutch band much like an automatic transmission. find a old british car mechanic and he'll know how to rebuild it, volvo used the same OD units that triumphs and MGs used in the 1970s.
There's seafoam for engines and trans tune for transmissions.
Yes, I am talking about the m46 with p or j type laycock OD units. I have a turbo so it's the more beefer one, I forget which is which.
I'm sure I can find a used unit or rebuild it myself on my free time or have it done, but I really don't want to a bunch more money into my turd that needs a engine overhaul (it's going through to much oil).
It's good for hauling so I keep it around. It would nice to get 27-28 mpg instead of 20 or less.
My 240 would also 'click" but didn't work. I removed the solenoid and put a bent metal coat hanger into the hole. It would not go in!! I pushed it and wiggled it and viola it wet all the way down. I replaced the solenoid and it still works perfectly. I also removed the solenoid and replaced it with a "plate" eliminating the solenoid altogether
michael, we're not talking about a AW7x automatic OD here. this is a manual transmission with a seperate OD unit on the output. if the OD solenoid was bypassed like that, you would either always be in OD (making 1st, 2nd too tall) oryou'd never be in OD, leaving you with no 5th for the freeway.
no problem, I just wanted to put that out there so anyone /else/ stumbling on this thread wouldn't get confused. the 4 speed manual with external OD was a 70s thing, they phased that out in the early 80s in favor of 5 speed manuals, so they are pretty rare today.
to 'guest01', I may have the OD service greenbook in my collection somewhere, I can't copy them (they are copy protected document files), or even screen print from them (really copy protected) but at least I could summarize the procedures for rebuilds. I glanced at a parts breakdown of the J units, phew, complicated beasties.
I opened my instrument cluster of my 1990 240. Found the broken gear and replaced put all back together only the odo will not work. When I found the gear the motor housing separated from the small circuit board. Did I break the motor?
Actually the M46 was used into the '90's, as ALL Turboed Red Blocks needed its stronger characteristics to work... The M47, a "true" 5 speed, started to show up in NA 240/740s in 1987 but it's not strong enough for turboed cars. The M46 Laycock De Normanville (I love the name) is an ancient beast but it works quite well and is still quite common...
BTW, I doubt that the Sea Foam for trannies will work...
as far as the seafoam, It's clearly clogged or not making pressure. I suspect it wasn't used very often when I got it, it had 147k the wires to the switch where cut, and I bought it from a guy in the city with already went through a clutch.
PinnacleWax
Jul 26, 2016 01:21 AM
PinnacleWax
Feb 16, 2015 04:27 PM
MotorCityAutoParts
Dec 28, 2007 09:59 PM
