transmission flange
Old Aug 23, 2016 | 05:56 AM
diesel4me2's Avatar
Exclamation transmission flange
I am having difficulty finding a wrench to remove the flange bolts holding the auto transmission flange to the drive shaft flange. There si a clearance issue. Has anyone had this same problem... solution? Did Volvo have a special 'thin' combination wrench for these bolts?
Old Aug 23, 2016 | 06:04 AM
act1292's Avatar
I use a box end wrench to remove these. 15mm if I remember correctly.
Old Aug 24, 2016 | 06:51 AM
diesel4me2's Avatar
Default flange bolts
the problem with a standard 15mm box end wrench is the thickness of the metal on the box end of the wrench.
Both flanges are slightly recessed where the bolts and the nuts make contact with the flange leaving about 2mm clearance between the hex face of the nut and the shoulder of the recess. This is because the flange is forged and the mating surface of the flange where it makes contact with the nut has been machined to provide a flat mating surface. I cannot get the wrench on the nut (and bolt) because they are recessed into the flange. A thin walled box end wrench would work. This is why I asked if Volvo used a special tool, a thin box end wrench.
Old Aug 25, 2016 | 06:05 AM
act1292's Avatar
Could be - my 15 mm box end is pretty thin. It is a tight fit but it makes it in there. Don't know what brand of tools you have but you may want to check out various options for a thinner box end.
Old Aug 26, 2016 | 03:22 AM
diesel4me2's Avatar
I have figured out the problem, thanks for your input. I thought I had to get the wrench on the nut. This is not the case. The flat on the hex nut is flush with the shoulder on the flange. Just put the 15mm box end on the bolt and turn. Simpler than I at first thought. Thanks everyone for their input.
boxpin
Jan 24, 2011 11:33 PM
ronananda
Dec 17, 2006 01:06 PM
mr.mitsubishi
Oct 21, 2006 02:01 AM
boostedbrick
Feb 23, 2006 01:30 PM
riaf28
Nov 27, 2004 10:57 PM
