Transmission Growl
Old Jul 12, 2006 | 09:00 AM
RedBrick's Avatar
Default Transmission Growl
I have a 92 745Ti (auto) with 106,000 and the transmission has started to make a slight growling noise in first and second gear when it shifts up through gears and down shifts through the gears. It is only noticeable in these two gears so far.
Fluid levels are good and clean.
Motor mounts are in good shape.
No shakes, no rattles, no shudders.
Any ideas on what to check for?
Thanks
RedBrick
92 744GL 88,000
92 745Ti 106,000
03 S80 35,000
Keeping it alive...one Volvo at a time!
Old Jul 12, 2006 | 08:40 PM
Default RE: Transmission Growl
Driveshaft Carrier bearing?
Old Jul 13, 2006 | 09:40 AM
RedBrick's Avatar
What would I be looking for in this bearing?
RedBrick
Old Jul 14, 2006 | 09:12 PM
Alot of times what happens is the Bearing seizes up then it spins in the rubber carrier.
Safely put it on Jackstands and spin the driveshaft and see if the bearing is spinning in the carrier.
Old Jul 26, 2006 | 05:25 PM
bli745's Avatar
Check center bearing and it's rubber cradle/mount.
240-FAN
Feb 9, 2015 05:45 AM
samwidget
1998-2000 model year V70
Nov 12, 2013 08:02 AM
240-FAN
Oct 25, 2013 08:20 AM
gearhead53
Mar 17, 2009 05:34 PM
Debsy
Jun 5, 2006 08:02 PM
