transmission problem
I have a 1989 volvo 740 gle.the problem im having with my transmission is it wont go into the final gear when im on the freeway.can anyone help me...please
Hello,
I would suggest you start by checking the level of your transmission fluid. Second, have you accidentally depressed the small switch on the left side of the gear selector? I manually over-rides shifting into 4th gear for towing purposes. If you have, you will notice an orange UP arrow lit on the right side of the instrument cluster. Andrew |
Fluid level is good,and the trans oil and filter is new,and the button on the side of the gear selector is in the right position.do you know if theres some kind of shift solenoid?
Originally Posted by classicman
(Post 386539)
