Trunk Leak (Still)
Old Aug 8, 2007 | 02:12 PM
colgate41's Avatar
Default Trunk Leak (Still)
Ok guys, i checked the other posts on this but nothing has helped. I have a 91 740 Turbo 4 door with a sunroof. When it rains my trunk gets wet, thoes little pockets on the right and left side are what get it. I checked thoes two hoses for the sunroof and there was crud jamed in them so i cleaned them out, but after hard rain today i saw that my baseball mits were all wet (they were stored in thoes pockes). Im wondering if the tail lights may give water a way in? Im kinda lost and any help would be great. Thanks a lot.
Old Aug 10, 2007 | 09:45 PM
VolvoDriver's Avatar
Default RE: Trunk Leak (Still)
hmm, that sucks...have you removed the carpeting around the area? look at the sealing on the trunk bay hatch...try pouring water around the area and look for possible clues...i imagine you might just want to investigate the causes...otherwise i'm not sure.
Old Aug 10, 2007 | 10:38 PM
Patdon10's Avatar
take a hose and spray your car. Spray on top, on sides, under car, tail lights. Find out where the water is getting in your carand trouble shoot from there.
Old Aug 10, 2007 | 11:32 PM
colgate41's Avatar
Ok, so after pulling up the carpet i saw that there is a hose comming from the power antenna and it was cloged with gunk etc and was also pinched so i cleaned that and set it right. Then i cleaned out thoes hoses because they had sticks and leaves in em, then today we got a ton of rain and i was excited to see my dry trunk but there was still a bit of water in thoes pockets. So tomorrow i will take out the tail lights and see if anything is stuck in or around them, because i saw a line of water trickling down from them, so that is my problem aera. I will let you all know how it goes. Annoying but ill take an old volvo over anything. Well for now at least. haha.
Old Aug 13, 2007 | 03:19 PM
JimKW's Avatar
I just read this thread and I was starting to rack my brain because I can remember having the wet trunk problem in my 85 760 Turbo Diesel about18 years ago. Then I read that you looked at the antenna and knew that was what I found back then too.
Ryan911t
Apr 13, 2014 10:19 PM
skooter66
Oct 28, 2011 08:08 AM
Mie518
Apr 30, 2011 02:49 PM
Vincef
Mar 18, 2009 08:42 PM
clash0901
Aug 14, 2007 12:17 AM
