Turn signal and tail light error!!!
Old Jan 18, 2009 | 09:19 PM
Mosesita's Avatar
Default Turn signal and tail light error!!!
Hello,
I have a 740 GL wagon, I have problems with the turn signal and tail lights.
1. When I have the headlighs or running lights off, turn signal works R&L no prob.
2. Running lights ON, Tail lights all on, except 3rd brake, R-turn signal onmy tails flash including reverse!!!
3. Headlamps ON,NO turn signal, just a dim green light on my dash. : /
Please help,,,
I replaced the switch, it is still the same. (got it at the junk yard)
Do I have to replce the lamps?
Check the ground? If so where do I start?
Thank you !!!!!!!!
Old Jan 18, 2009 | 11:27 PM
tedv's Avatar
Default RE: Turn signal and tail light error!!!
I'd check the rear lights circuit boards beside the grounds. The switch and the bulbs are not the problem.
Old Jan 21, 2009 | 06:06 PM
78vovlo244's Avatar
Check that the wires are all indpedent from each other i had this problem and it was becuase of terrible wiring thanks to the previous owner so i rewired them all but that might be more then you'll need to do.
commoncold
Jul 22, 2014 05:41 PM
commoncold
Jun 25, 2014 10:38 PM
shadowpyro
Mar 7, 2010 02:52 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
