Turning the boost up?
Old Jun 29, 2007 | 01:05 AM
getsideways's Avatar
Default Turning the boost up?
hey guys, new to volvo's... i have an 85 740 turbo plus+++... hehehe... i've been hearing rumours of a manual boost controller installed from the factory in this "plus" package.. if this is true how shall i turn it up..
Old Jun 30, 2007 | 09:26 AM
Default RE: Turning the boost up?
You got really lucky that system is very Rare and is a factory setup.
The boost is already turned up.
I wouldn't turn it up anymore unless you first install an aftermarket boost guage.
Old Jul 1, 2007 | 03:01 PM
yah i know its very rare.... i'm happy to have it... i'll probably get a boost gauge, safc, and a wideband.. then i can safely tune it up to around 12-14 psi.. how much can the stock internals handle? and i also want to lower it.. sits way to high.
Old Jul 2, 2007 | 05:39 PM
I believe about 15 is max on the 4 cylinder.
Yes they look sweet lowered.
Old Jul 3, 2007 | 11:49 AM
ktmrider193's Avatar
post some pics! ive never heard of this + model
Old Jul 3, 2007 | 09:02 PM
i'll post pics soon.. i don't want to until i get a new taillight and front corner light.. both are smashed.. haha.. and no i didn't do it.. it came like that.. but other than that the car is mint.. i just lowered it about and inch... with some universal coil spring clamps.. but it doesn't look very noticeable.. i'm going to have to get creative if i want it lower..
Old Oct 29, 2009 | 03:02 PM
brf0007's Avatar
I have been looking to lower my 940 turbo and was considering spring clamps, are they safe to drive with? are they legal? where did you get them? how is the ride quality?
thanks
Old Oct 31, 2009 | 01:51 AM
TIPSP's Avatar
Got Boost?
ipd sells springs.
fcpgorton sells springs.
bne sells coilovers.
I have the TME versions.
I am running 15psi.
Old Nov 1, 2009 | 02:40 AM
Typhoon's Avatar
Before you wind up the boost, you should do a few things. A thorough tune up is essential, making sure your cooling system is good is also essential. Check and verify fuel pressure.
You WILL need chips if you want to spend much time over 12 psi, the factory maps default around there and go pig rich and retard timing like crazy.
You should also do an exhaust system, you will gain a free 2psi of boost just with a free flowing 2.5-3" cat back system.
These engines will live forever at 15-16 psi, 22psi is not uncommon. Transmissions become a weak link at these boost levels though and the stock turbos are way out of their efficiency range at 22 psi, so either factor in a bigger turbo, or set it all up for 14-16 psi and enjoy gobs of midrange torque. These engines do not need to rev out to make good horsepower.
My car is a solid low 14 second car with Fred's chips, 14psi bost and an exhaust. Everything else is bone stock.
Running a car with decent boost is a bit of a commitment though. You MUST run the best fuel all teh time, be religions about tune ups and maintenance and be super paranoid about fuel pressure. As an example, I replaced my in tank pump just because I didn't like the sound it was making. .
Regards, Andrew.
thecheat
Sep 22, 2010 08:48 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
