Volvo 940 lpt 2,3 petrol not starting
Can anyone help please?
Car was running fine ,stopped at traffic lights not started since. Done the following checks. Fuel up to injectors,12 volt at injectors.Injectors not passing fuel on trying to start. Sparking ok at the plugs. the crankcase sensor reads 160 ohms Any ideas? |
Have you checked the timing belt? May have snapped.
The crank position sensor is tricky. It may have the right resistance but that doesn't mean it's sending the right signal at the right time. And if it's off it will override all other functions. They're cheap enough to replace and that's where I'd start first.
Originally Posted by Moetheshmoe
(Post 509006)
thanks for your reply,I have just been testing it and the wiring is a bit cracked.So its worth a go. thanks |
Hi
I changed the crank sensor with a new ,still no joy. No idea what to do next! |
Fuel
If your getting fuel to injectors but not firing then problem is your radio suppression relay wiring or relay
black square bix near radiator overflow tank You should have 1 or 2 of these try that or check that Goldenblock |
