Volvo 940 lpt 2,3 petrol not starting
Old Mar 3, 2022 | 11:55 AM
gjores's Avatar
Default Volvo 940 lpt 2,3 petrol not starting
Can anyone help please?
Car was running fine ,stopped at traffic lights not started since.
Done the following checks.
Fuel up to injectors,12 volt at injectors.Injectors not passing fuel on trying to start.
Sparking ok at the plugs.
the crankcase sensor reads 160 ohms
Any ideas?
Old Mar 4, 2022 | 11:45 AM
act1292's Avatar
Have you checked the timing belt? May have snapped.
Old Mar 4, 2022 | 02:04 PM
Moetheshmoe's Avatar
The crank position sensor is tricky. It may have the right resistance but that doesn't mean it's sending the right signal at the right time. And if it's off it will override all other functions. They're cheap enough to replace and that's where I'd start first.
Old Mar 4, 2022 | 03:32 PM
gjores's Avatar
Hi
thanks for your reply,I have just been testing it and the wiring is a bit cracked.So its worth a go.
thanks
Old Mar 29, 2022 | 04:00 AM
gjores's Avatar
Hi
I changed the crank sensor with a new ,still no joy.
No idea what to do next!
Old Mar 29, 2022 | 05:29 AM
Goldenblock's Avatar
Default Fuel
If your getting fuel to injectors but not firing then problem is your radio suppression relay wiring or relay
black square bix near radiator overflow tank
You should have 1 or 2 of these
try that or check that
Goldenblock
AlexMacDonald
Feb 4, 2023 10:31 PM
oilman940
North East
Nov 13, 2012 09:20 PM
HECTORPORTALUPPI
Feb 27, 2011 04:41 PM
wtkc940
Sep 5, 2010 03:44 AM
pitttl
Nov 15, 2005 10:23 AM
