wet weather problem appeared
Ok guys, 89 740gl b230f
yesterday when my wife picked me up, the car had a bit of a problem on the way home. It drove fine in a moderate L.A. rain; then when we went up a small hill, the car lost power but continued. It stumbled like it wanted to die. My wife floored the pedal, but still the same reaction from the car. When we were back in a flat section, it also produced high revs 2500-3000 rpms on the tach, but the same lack of power. Flooring the pedal produced no effect. After about 5-10 min, the problem went away, indicating some type of water problem. I'm thinking it might be the crank sensor getting wet.
so any thoughts?
so any thoughts?
beardog, I had kind of the same proble with my 740. Mine would either loose power in medium rain or die in heavy rain, not consistantly but one time is to often. after trying several diffrent things (one was crank sensor) i got a water hose and ran it on hood and windshield. I discovered the weather stripping on the fire wall for the hood at the distributer had split and when it rained my wipers sent it all right on to my distributer cap and wires. Once i siliconed the weather stripping --problem solved. Hope you find this useful. Enjoyed you quotes on the bottom of your page-- so true!
thanks, about the quotes, I've run them for years on the bottom of my emails. I think I sent a couple of letters to my senators a couple of times with those quotes attached. I don't think the responses were that positive, but then again they did seem like canned email.
I look into the weatherstripping.
I agree with bubba240. Put a timing light on each spark plug wire and see if you get light. Over time, the resistance in each wire builds up. Or, run a resistance check on each wire. Brand new, the coil wire should be ~2 kohms and the spark plug wires ~6 kohms (at least for my brand new Bosch wires). Before I replaced my spark plug wires, I was getting all sorts of gremlins.
I have had the same problem after heavy rains - there would be excess moisture in the distributor cap for no reason. Buy a product called ignition sealer spray for $4-$5 dollars. Spray distributor and wires and you will not have the problem again unless you have a cracked disributor cap. Let me know how it works.
JamesO84
09-13-2013 05:13 PM
Viking70
12-24-2009 04:06 PM
