where can i get a 1992 940 wiring schematics?
Old Nov 1, 2007 | 01:45 PM
Kervin's Avatar
Default where can i get a 1992 940 wiring schematics?
Im trying to replace my radio with a new one , my dad said we need to know what each wire is so we need schematics to outline which wires will go with the radio's wires when we splice them. Any ideas?
Old Nov 1, 2007 | 02:13 PM
01_fast_ride's Avatar
Default RE: where can i get a 1992 940 wiring schematics?
Hello Kervin,
Your dad is wise. If you are replacing the factory radio then the car should still have its factory wire harness. Several companies make wiring adapters so you don't necessarily have to splice the factory wiring. You would only need to splice the adapter (clearly labeled) to the new radio wiring (also labeled) then plug the adapter into the factory harness.
If the wiring on your car has already been hacked up, you have a mess on your hands. But there is a thread named 'radio wiring' that has the factory color coding for all the wires.
Old Nov 1, 2007 | 02:35 PM
Kervin's Avatar
can you link this thread? I cant find it : / And yesterday we already cut the wires , oh well the only thing i can do now is get the info for the wires and finish it finally.
Old Nov 1, 2007 | 02:50 PM
No problem, the thread was started just the other day as a matter of fact. This was posted for a 94 but the color codes will still apply.
https://volvoforums.com/m_78680/tm.htm#78793
Old Nov 1, 2007 | 04:11 PM
onryboy's Avatar
1991-93 Volvo 940 Series Stereo Information
Constant 12V+
Yellow
Switched 12V+
Red
Ground
Black
Illumination
Light Orange
Dimmer
n/a
Antenna
Left Rear
Front Speakers
5 1/4"Doors
Left Front (+)
Blue/Yellow
Left Front (-)
White
Right Front (+)
Gray/White
Right Front (-)
Gray
Rear Speakers
6" x 9"Rear Deck
Left Rear (+)
Yellow/Brown
Left Rear (-)
Yellow/Green
Right Rear (+)
Green/Brown
Right Rear (-)
Green
Old Nov 1, 2007 | 05:40 PM
Kervin's Avatar
so far ive only been able to get the front right speaker to work . Im done for today so hopefully i can get the rest up tomm.
Old Nov 2, 2007 | 04:42 PM
wojeepster's Avatar
https://www.volvotechinfo.com/index....m.serviceparts
Old Apr 15, 2010 | 03:14 PM
bossboy2's Avatar
Unhappy
Make sure you get your speakers wired correctly. If not, you can blow them AND your head unit. If you can't figure out which wire is positive or negative, simply hook your speaker's wires to a nine volt battery, MOMENTARILY. When you have the positve from the battery connected to the positive on the speaker and the negative likewise, the speaker will push outward. If you have them backward the speaker will pull inward. I learned this back in the day when I was a roadie.
hines1268
Oct 13, 2011 11:12 AM
kc2mrg
Mar 29, 2011 06:04 PM
JAO1988
Jun 10, 2009 11:28 PM
brf0007
Jan 11, 2009 01:28 AM
claya
Jun 17, 2008 05:26 PM
