why no spark on the 240?
does this 1992 have bosch ezk or regina/rex ignition? afaik, they came both ways.
see if there's pulses at the input to the power stage when the car turns over. is there power at the hot side of the coil when the ignition is switched on ?
If any of your fuses look grey rather than silver, or even just anyways on principles, I would replace ALL of them with copper/brass european ceramic fuses. the "Buss" fuse stuff sold in the US is JUNK.
go to ebay, and look for someone selling "Mercedes W124" fuses, they will sell a kit with enough fuses to do 2 cars probably. replace ALL your fuses with these, clean the inside of fuse holder spring contacts with a pink pencil eraser as you go.
http://www.ebay.com/sch/sis.html?_nk...ramic+Fuse+Set
see this
MBCluster.com Mercedes W140 Instrument Cluster Repair Homepage
for an example of why.
I've taken seemingly good silver/tin fuses out of volvos and had the end caps turn to dust.
see this
Kim Gregory
Feb 20, 2013 08:02 AM
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
