Windshied wiper motor installation instructions?
RE: Windshied wiper motor installation instructions?
Here's what the Haynes manual says:
1. Disconnect the neg cable from battery
2. In the engine compartment unplug the wiper motor electrical connector and remove the mounting bolts
3. Inside the passenger compartment, remove the glove box and sound insulator panel if neccessary, for access to the motor drive-to-wiper crank connection.
4. Hold the motor drive crank with a wrench, remove the crank bolt and detach the crank, then lift the motor out. If the motor isn't in the park position, it will be necessary to pry the motor crank arm clip and detach the arm at that point.
5. Installation is the reverse of removal, making sure the motor in in the parked position.
