wire ID in dash
wire ID in dash
I’ve found a handful of unplugged wires under my steering column and want to know what they’re for and what i should do with them.
orange and black wire- these came from the harness that was out the back of the radio (maybe for the amp that came in turbo models?)
red wire coming from the female radio harness
one of 2 green wires, looks like it’s above the brake pedal?
this black wire with a spade connector on one side
*not pictured but the connector coming from the back of the radio has one long yellow wire that crosses under the steering column and goes into the trim with the fuse box?*
If you need more pictures/ descriptions i’m happy to provide, i just want some peace of mind that these aren’t important
this is for the 1987 240 ? gonna take a whole bunch of cross rerferencing the wiring diagrams to figure that out.
if you could enumerate the wire colors and pin numbers at each of thse connectors, that would make it a lot easier. pin numbers are almost always molded into the connector shells.
for sure the radio uses a 3x3 block connector line one of those, but so do lots of other things.
foldingchariot
12-30-2023 04:53 PM
