1995 Volvo 960 speed signal missing
Old Aug 7, 2010 | 09:59 PM
aljoy1's Avatar
Default 1995 Volvo 960 speed signal missing
I have a 1995 Volvo 960 and the speedometer stops intermittently and then the car goes into limp mode. The blinking orange arrow goes on as well. Seems to start when driving locally and at full stop. Have had it to the tranny shop and local shops and had rear speed sensor replaced without fixing the problem. No broken wires and the connections on the sensors / main plug by the tranny seem good. Any idea what might be causing this - A1 fault code of 2-3-2 (also A3 code of 1-5-5 although that is probably something else). Thanks.
Old Dec 22, 2020 | 05:53 PM
Payton Chernoff's Avatar
I have a 1995 960 wagon with the same issue. I’ve been putting off taking it in to get the speed sensor replaced in case that’s a waste of time/money. Were you able to find a solution?
Old Dec 22, 2020 | 07:51 PM
Yes, the speed sensor on the differential - do not go bad. (at least in 38 years I never saw a bad one) There is a problem somewhere else.
Kabwemech
Dec 16, 2016 11:20 PM
LOVEvolvos
Jan 20, 2013 09:02 PM
magorahog
May 26, 2010 01:21 AM
aljoy1
Sep 19, 2008 07:59 PM
hoochbob
Jun 21, 2004 12:33 PM
