88, 760 turbo remove crankshaft pulley
I am in the middle of changing my timing belt , tensioner , and crank seal .
I removed the centre bolt for the crankshaft and the pulley does not come off ... this may be a dumb question but do i need a puller to get the pulley off on this application ?? There is not enough room to get my harmonic balance puller in there ... any suggestions ? |
RE: 88, 760 turbo remove crankshaft pulley
Usually a prybar between the pulley and the timing cover carefully prying working from side to side will get it off.
Becareful not to break the timing cover. |
It must be stuck on there good caus i screwed around with it for an hour ! .....
Guess i will give it another go |
