88, 760 turbo remove crankshaft pulley
Old Aug 17, 2007 | 10:24 PM
rmcmighty's Avatar
Default 88, 760 turbo remove crankshaft pulley
I am in the middle of changing my timing belt , tensioner , and crank seal .
I removed the centre bolt for the crankshaft and the pulley does not come off ... this may be a dumb question but do i need a puller to get the pulley off on this application ??
There is not enough room to get my harmonic balance puller in there ...
any suggestions ?
Old Aug 18, 2007 | 08:46 AM
Default RE: 88, 760 turbo remove crankshaft pulley
Usually a prybar between the pulley and the timing cover carefully prying working from side to side will get it off.
Becareful not to break the timing cover.
Old Aug 18, 2007 | 01:23 PM
rmcmighty's Avatar
It must be stuck on there good caus i screwed around with it for an hour ! .....
Guess i will give it another go
josseppi
Nov 30, 2010 04:49 PM
tennentssuperblack
Mar 25, 2009 03:12 PM
lummert
Feb 22, 2008 04:45 PM
act1292
Nov 10, 2007 08:41 AM
azeezn
Jun 3, 2006 11:28 AM
